Originally posted by Rock Doctor
View Post
Kold Kutter ice cleats on supertracks
Hi Larry,Originally posted by LarryW View PostHey Tim,
Just curious what are the bolts for extensions? Do the threads get damaged, or I mean Im assuming they do. Are they threaded rod or what do you do to take them off? Cool track though!
Just got a chance to inspect the screw in studs and bolts after putting 26 miles on it this past week in WY and while riding with Dan and John. Here is what i have found.
The ice screws are starting to show some wear (but super inexpensive at only $9 for the whole set of 120) from spinning on rocks and pavement and i should probably start to look for a little higher quality carbide tiped version to replace them with whenever its needed. The bolts actually look really good and they only show damage on the very tip that is always riding on the ground. (They were also pretty inexpensive grade 2, 5/16" x 2" carriage bolts from the local hardware store)
Didnt break or show any signs of bending any of the bolts or gold digger ice screw (except for the one bolt that i lost on the trail the morning that we all started riding together)...even the threads look pretty good considering all the rocks and stumps we were driving on.
Here are a few pictures and some close up shots.
Tim
They seem to hold up quit well actually. If you ever do need to remove the nuts from the bolts looks like you could cut the bolts off easily with a cut off wheel just on top of the nut. Probably wont hurt the tracks with the cutting heat up there. Thanks for the updated pictures. Sounds like you've had a blast!
