argo frontier tire question
  • argo frontier tire question
    where can i buy argo frontier tires for my max II im kind of stuck between them and the carlisle at101s
    watch this link these tires are sick in the water
    Max II with 24" Tires Video by Brandon - Myspace Video
      You can only purchase the tires through Argo so contact your local dealer.
        There is an advantage to buying from a larger volume dealer.....they can match the tires so they are all uniform size.
        Tires
          thanks man those prices arnt horrible i figured it out im gonna pay atleast 550 for a set of tires for my max so i just have to get over it hahah
            I've got some brand new ones for $90 a piece.
              really now what sizes are they i need a 22x11-8 or anything that will fit on a max II with the outer muffler
                The new units have an internal muffler. Look at pictures of the rear of the machines and you see the exhaust pipe stick out. Richards sells conversions, but you could also make it yourself. The hole in the tub from the old exhaust exit is blocked off with a plate and new heat shielding is installed around the new internal muffler. Welcome to Richard's Relics Parts for ATV's or go directly to R.I.
                With the internal muffler you can put at least 24" tires on.
                  i was able to fit 24" frontier tires on my max 2 with the external exhaust just was real close to the tub in the middle and front .
                    so the exhaust wont rub the top of the tire and i can always set the bearing about a 1/4 inch out u know then the tire wont rub the tub because im bout to fix the inbushing issue ith my axles and put inner bearings
                      external muffler/tire?
                      i have a 95 maxII and i want to put the frontier 24x10-8s on it anyone have bigger tires or some tires and will they fit on my max with it having the outer muffler and how much is a internal exhaust kit
                        Richards used to sell mufflers (kits) for around $350, but they have disappeared from the web site????? I would call R.I. and see what they charge. You may also want to do it quickly while they still have them. I heard a rumor that new Max's were going to be powered by Tecumseh motors instead of Briggs. I thought Tecumseh was out of business, but apparently they have started production again. As for the tires....MaxII axles are spaced 25" center to center, that means a true 25" diameter tire will touch the tire beside it.
                        Some 25" tires are over 25" and some are less. I want the 25" frontiers because of the extra width, 12" vs 10" on the 24s, but there just isn't enough clearance Now I'm considering stretching my frame to make them fit.
                          You can put the 24" tires under a max2 and clear the muffler. With room to spare it's a real close on the tub in front and middle. I put a set on last week to try it. You will have to heat your tub though. Truefully. Its not worth it. For an extra 3 quaters of an inch of ground clearance. Save your pennies and but a set of adair tracks for it.
