I have a hustler 950, about an 1984. Anyone know where to get the metal rods that hold the tracks together? The tracks I have, all the rods were rusted. Also when my friend and I put the tracks on to try them out. Is there an easier way to put them on? We about died trying to install them. Are the tracks suppose to be sloppy or loose so that the tires just roll in them or are they suppose to fit so that the tires wont spin in them?
Track Repair
I have the same problem. Unless you use stainless steel (very expensive) rust will be a problem. I bought a few brass brazing rods (3/16") to try, threading the ends 12nc24, using stainless nuts. Biggest problem is getting old rusted pieces out. Any ideas here?
Don't know much about track tension, looser is better than too tight.
I havent tried removing the rods. I will in the near future. I'll attempt to make a clamp that I can fix to the tread. Same concept as a "C" clamp. Pushing the rods out. Im also going to try a heat gun as well to warm the plastic. As for replacement rods. Im not gonna use SS. Im using aluminum rods. The way the treads are mated together. The aluminum wont be subjected to bending. Ill make the rods so that they can only be inserted from one side and they will have a right angle bend at its end. Instead of just putting a typical nut on the end of each rod to secure their position. Im looking more at the type fasteners you see that holds the handles on a hand saw. They are called sex screws. This way they will be flush with the tracks surface.
look on argo if you want to see what i did .and the response. to such. But bascially i used 1/4 steel rod cold galv. them then a bit of never seize i turned the keepers on my lathe tapped for set screw. I tried to sace them in the beging the pins i mean after a bit i used a thin wheel cut off for grinder to cut the track apart at the pins never did hit the plastic much easier to get little pins out than one big one.once i was set up at lathe and table it went pretty quick but it was a fight in the start.
