Hi All. Just put my tracks on as ice fishing is just around the corner. I was wondering how much slack or free play should be in the tracks once installed. The tracks are used and the stock tires are about 40% used. I was thinking of trying to remove 1 track section to tighten them up. The tracks are original argo units in reasonable shape. Any insight would be appreciated.
argo vanguard 6x6 tracks
Hey Julio,s are these the wide supertracks or the standard, shouldn't be a ton of sag but if you have more than 5 or 6 inchs with the one side off the ground you can increase your tire pressure to take it up a bit.Originally posted by julios57 View PostHi All. Just put my tracks on as ice fishing is just around the corner. I was wondering how much slack or free play should be in the tracks once installed. The tracks are used and the stock tires are about 40% used. I was thinking of trying to remove 1 track section to tighten them up. The tracks are original argo units in reasonable shape. Any insight would be appreciated.
Standard tracks. Will try. dropped pressure to 3.5 lbs to put tracks on but will go to 5. sags about 2 inches between 1st and 2nd axle while on ground at top of track. thanks a bunch was beginning to think I had an odd question and didn't word it properly
