Hustler Plastic Tracks
  • Hustler Plastic Tracks
    Im curious as to how many links of plastic track should be on a Hustler with 21x11x8 tires. I presently have 30 pcs each side and was suggested that if I lift my hustler off the floor. The section of the track that hangs down under the center wheel should be no more than 2inchs from the tires base. Its more than that.
    30 pieces per side is the correct number. Just a suggestion, but what if you ran some 20x10x8 lawn mower tires and then removed a section or two of the tracks.
    20" Rear Superturf Tire & Rim Assembly - Used (05644), www.bmikarts.com : BMI Karts & Supplies : Go Karts Parts : Racing Go Kart Parts : GoKarts : Versailles, Ohio : USA : Indoor Track : Tips
      I was thinking of doing the same thing! I even saved that link you put up from the other time we both read that thread about them. It would do me good. I would get stuck without tracks on my property.
