Adiar Tracks, all others need not apply
How do the Adair tracks do in the snow? They don't look like they would have enough surface area for good flotation on the white stuff?
I like the fact that you and I both run some nasty conditions, and have different designed tracks, we should be able to compare notes as we go.Originally posted by mudbug3 View PostRock Doctor
I talked to the Canadian Mudd-Ox dealer that leases his machines out to the oil companies ,and he told me that they were running 30 psi in the Adair metal plate tracks. I have'nt got the chance to try the Adair rubber belted tracks yet. For the hash conditions that I put my Argo 6x6 through, Tim recommended that I should get the metal plate track design. So far I am very happy with the metal plate tracks. With the added inprovements on this track design ,they work even better than the chain link design that I took off. Each new track design that Tim builds is even better than the one that he built before it.
Rock Doctor
Those Turbo Diesel Mudd-Ox's had to run 30psi in their tires to keep the Rubber Tracks mounted (IIRC)Originally posted by mudbug3 View PostRock Doctor
I don't drive this aggressive normally, but I really wanted to test these new metal plate tracks to see if I'd have to make any adjustment to them when I got home from the ride. Because the Adair metal plate tracks have held up so well on two commercial ,turbo diesel, Mudd-Ox 8x8's , I decided these were the tracks that I wanted for my machine.
Now I'm wondering how much pressure they are running to keep the Adair Tracks mounted. Any idea?
Have you also tried the Belted Tracks? If so, could you describe the differences, if any? I almost bought the Plated Tracks, but ended up going with the Belted option (Just so there is no confusion here, I am more than happy with the Belted option, they are working awesome so far.)
With that kind of traction, you would probably still have the nastyest holes all to yourself even if the park was fullOriginally posted by mudbug3 View PostObsessed
Noel and I went to river run park the week after the Mudfest event. We decided to meet at the park in the middle of the week so we could have the mud holes all to ourselves.
Rock Doctor
Obsessed
Cool place to ride Mudbug ... Was it just yours and Noel's argos at the park or was there some other 6x6's riding with you? Looks like your HD is getting around pretty good with the new shoes :-) ....wildtexasranger said the park was really packed at last weekends big event...
TimLast edited by Obsessed; 10-27-2012, 11:28 PM.
These are the new metal plate Adair tracks that I recently installed on my Argo 6x6.
Comparing the new Adair, metal plate tracks to the Adair, case hardened ,chain link tracks that I took off, these are the differences :
1. Each grouser is spaced 3/4 inches farther apart
2. Each grouser is about 1/2 inch thicker
3. Each grouser extends 1/2" inch longer down the side walls of the tire, making it harder to walk out of track
4. Each grouser has a rounded profile compared to the flat profile of the chain link , Adair track design ,and making side to side turns is now even easier. This really compliments the Admiral steering transmission
5. Each grouser is 3/8" of an inch taller in the cenrter of each grouser to provide more traction
6. The chain link design, Adair tracks have a 3 3/4" inch , UHMW spacer that's between each grouser on either side ,but the metal plate design in all open for more traction.
7. The metal plate design has two 3/16" inch metal plates that fit through each grouser on either side and connected to two 1/4" inch steel plates in between them. The 3/16" inch steel plates and the 1/4" inch steel plates are held together by a 3/8" stainless steel shouder on either side
8. The metal plate design Adair tracks keep the tires centered in the tracks even better than the chain link design Adair track
Keith, I can't wait to see your Hustler Bigfoot in that line up with 2" grousers.
For all you Max owners interested in Adair tracks. I took these pictures when I had my Max IV fitted for a custom set of 18.5" tracks to go over my 25" Rawhide III tires. It compares my Max to the standard track/tire combinations Tim sells for Max vehicles.
It's cool that a place like Adair Argo sales can make almost any amphibian so capable.
Keith.
Thanks Dan, Jason ran the Bigfoot with tracks this weekend at a friends property. He was able to run the old trails in the back marsh that had only been winched through previously and had not been run for 15 years. People were also amazed at how it would effortlessly climb out of the pond against a small 90 degree bank. He gave lots of rides through the marsh and even caught some snapping turtles.Originally posted by mightymaxIV View PostKeith that is a very impressive video. The Fact that you have tried and failed with your MaxII and Aqua Torque tires makes it that much more impressive. I know of no other machine that could move in that kind of muck without Adair tracks. That little Bigfoot of yours and other Bigfoots that I have seen up close and personal with Adair tracks continue to impress me with their capabilities.
I should note that my Max IV with factory rubber tracks will become hopelessly stuck in this hole while the Bigfoot drives around it to grab the winch cable. The Max IV with factory rubber tracks will just push the muck up infront of the tracks until it can't move forward over it and then sort of high centers itself. It kind of sucks because after you winch yourself out the muck and weeds are all stuck up around the bearing support bar and extensions and it is a pain to get it all cleaned up again.
Keith.Last edited by kghills; 06-13-2012, 06:55 PM.
Keith that is a very impressive video. The Fact that you have tried and failed with your MaxII and Aqua Torque tires makes it that much more impressive. I know of no other machine that could move in that kind of muck without Adair tracks. That little Bigfoot of yours and other Bigfoots that I have seen up close and personal with Adair tracks continue to impress me with their capabilities.Originally posted by kghills View PostWould you send your 10 year old into a hole like this? Not without Adair tracks.
Here is a video I shot with my new phone. It is in the woods behind our house and is the reason I outfitted a machine with Adair Tracks. I sent Jason into the hole to do a quick loop. He decided to do two but he made it look so easy I just included once around. The farthest I have ever mad it with AquaTorques is about 6 feet. With my Max II I could get about 15 feet with a good run. Enjoy.
Keith.Last edited by mightymaxIV; 06-12-2012, 12:15 PM.
Never seen a Crocogator but there are some very large Snapping Turtles that live in there. They wander up by the house now and then as they move between marshes. I think my wife has a few pictures and the old Austrailin Sheperd had a pretty nasty scar on her nose from tangling with one.Originally posted by Rock Doctor View PostNow that's a Muck Pit, ........................ Any Crocogators in there? lol.
Doug, I started a thread under the other trail rides forum with the pictures Tim took of me.Originally posted by foxvalley View PostHey Keith, thats quite the pig pit you have! Looks like the boys are having a blast. Did you post any pics of the ditch ride in Iowa? Looking foward to our next get- together,but we need to coordinate it with the next time Tim gets up this way.
http://www.6x6world.com/forums/trail...g-grounds.html
Let us know when the bugs will allow us to ride again. Keith.
