transmission leak
  • transmission leak
    Has anyone ever used bars leak transmission fluid to stop a slow leak in the trans? It claims it is safe for all types of transmissions.
    What transmission are you thinking of putting it in. I wouldn't use it in any of my vehicles, but a t-20 is simple enough to fix right and I seriously don't think it would work in a scrambler transmission.
      Scrambler trans good one Drew.
      I believe he has a t-20 in a hustler.
      Snowman: Where is it leaking from? I just bought seals from motion industries for a t-20 I have....I can give you the part #s (output shafts and input shaft), the plungers are "o" rings available at any hardware store, and the case half seals (paper gaskets) are available from Recreatives only. The case halves could be sealed using silicone or other sealant, but I wouldn't do that either because it will be very, very hard to get it back apart due to the lipped design.
        I have to take a better look at it to see where it is leaking from I think I am going to take it out of the machine and inspect it further. Thank for the replies.
