T-20 fluid change
  • T-20 fluid change
    Newbie here getting ready to change all fluids
    what is the easiest way to drain the old tranny fluid on a Max II. I have searched around and seen people winch them(don't have yet), lift with tractors and bobcats( been trying to talk the wife into a bobcat for awhile with no success). I was thinking of pushing it up ramps on the back of the truck and chock the wheels but not sure if that will be steep enough. I guess the other option would be suction with the shop vac and 5 gallon bucket.
    All suggestions greatly appreciated!
    Thanks
    Brad
    The problem is that the lower drain plug is actually the upper level of the fluid. Suctioning won't work well because the drums/bans are in the way. You just won't get enough fluid out.
    Certainly there is some way you can incline the machine....custom ramps?
      Thanks buggyman! Was thinking about running some short 2x8's up to the bed of the truck and leaving on the incline with the wheels chocked. I was just concerned if I could get it vertical enough to fully drain. I will do it this time but will be picking up a winch in short order. Just need to have a mount fabricated.
        I took an air hose to the upper hole and used air pressure to blow the oil out the bottom hole.
          Thanks sounds very easy, but how do you keep it from blasting out the drain hole and making a huge mess?
            I cut a gallon bleach bottle to fit down by the hole and blew easy with my air nozzle and the oil came out slow. as most of the oil came out I blew harder till only air came out. I think it cleaned out pretty well.
            Mike
