I'm really new to this 6x6. Just changed the T-20 fluid, 14 oz's came out. Put in 28 oz w/ 4oz. runs well when in gear. any ideas where to statr first ?
1995 MAX II - T-20 TRANS Slips out of gear ?
Disconnect the linkage to the trans and then shift your diamonds by hand. If they don't feel like they are locking into place then you have bad or broken detent springs. There is one on each side so if one feels different than the other one spring is bad.l like to buy stuff and no I don't do payments!
It sounds like you are trying to shift it while the clutch is still engaged. You shouldn't do that. You should only shift it after the engine is slowed down enough for the clutch to disengage. You will hear it kick out, then shift it. If you don't do that, its like doing a neutral drop on an automatic transmission.Borrowing tools is for the weak.
2000 Max IV, 25hp Kohler Command, 26" Titan Tru Power AT's
1996 Max IV, 18hp Briggs, 24" Serwas
1998 Max IV (project in waiting)
1995/1999 Max II, 16hp Briggs, 21" Rawhides
Hustler 950 (Project in waiting)
might want to check the primary clutch to make sure it is completly disengaging . if not it could be keeping enuff tension on the trans to not completly take to full engagement when your shifting. i just went through this with one of my other units with a centrifugal clutch.whats a four stroke ? you mean they make low h.p. motors that dont smoke ? who wants that ????
like Henry FORD iv always got a better way
You should never try to shift the transmission with the engine revving. It should only be at idle (make sure your idle isn't set too high as well) when you shift gears or you'll be forcing it and it'll shift hard.Originally posted by 814cannob View PostI hate to say both. When stuck in snow it pops out of gear. I may be trying to force it to much. Once the engine idles down it seems to go in to gear better."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
