Hi, folks.
Some of you know I am building this tracked vehicle using a T-20 and a Duromax 16hp engine and a Comet clutch. I have only the gear reduction of the Comet clutch before I run a long #50 chain through about a 2:1 reduction using say a 15-tooth sprocket driving a 30-tooth sprocket at the T-20 inputs. I think that is good so far. But then, the T-20's approximately 6:1 reduction kicks in as the final reduction to the final drive shafts to the outside world. I have #50 sprockets (15-tooth) welded (nicely) on on the T-20 output shafts that use a very short run of #50 chain to get to the 15-tooth sprockets on the final axles. Probably the loaded vehicle weight is 1800 pounds with fabulous traction. What are the odds the #50 chain at the final drives will be breaking? Can a special brand of #50 work better. Will it just need frequent upkeep due to stretching? Am I destined to mill off the #50 sprockets and weld on #60. Thoughts?
Thanks.
Thanks.
