The admiral transmission in the new Argo's uses a triple differential that steers with the disc brakes and calipers mounted on either side of the transmission.
What if you had longer out put shafts made that would take a sprocket and also a disc brake rotor and caliper? Could you then remove the bands inside of the T-20 and use the hydrolic brake calipers to activate each brake rotor to steer left or right? This way you'd never have to replace the drum bands when they wore out.
