I want to replace my drive belt with one that is 1 1/4 " wide.
The belt that came with it was 1 3/16" and is running deeper into the secondary as it wears on the edges and the secondary cant close any further.
Question is will a wider belt work with my primary or will it engage too soon.
The primary clutch on the rotax lists a 1 3/16" belt should be used but im thinking if I install a wider belt that is a bit longer it might be ok.
how else would you want it set up?
