What type of oil should I put in the T-20 in my Wild Wolf. I am not sure what it should take and if I can add some Lucas gear oil. Any help?
T-20 oil
No do not put any gear oil in a t-20. It can delaminate your bands and cause very bad things to happen to expensive parts. Atf III is what re t-20 uses. Some people use a limited slip additive or use a full synthetic. If gear oil was used in your t-20 it is best to take it apart to inspect the bands and clean interior components in a parts washer before installing.Originally posted by PLANTC View PostWhat type of oil should I put in the T-20 in my Wild Wolf. I am not sure what it should take and if I can add some Lucas gear oil. Any help?l like to buy stuff and no I don't do payments!
Like Drew said, NEVER use gear oil in a T-20. Use one quart of ATF type F. You can add about 4 ounces less than a full quart of the ATF and put 4 ounces of the limited slip differential additive to keep the bands from chattering if need be."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
thanks for the help. Gear oil wasn't used in the trans. I am not having any issues with it right now. I just got my 4 stroke conversion done yesterday. Before I start really putting it through it paces. I wanted to change the trans fluid to have an idea on when it was done.
