Ok so I mounted the engine in my hustler just to find two of my bands were worn out. I checked with one source and they are saying $70 per band with exchange? Does this sound right? At that cost I think it would be cheaper to buy a used trans and have it shipped?
Borg Warner T-20 rebuild questions
My psychic powers tell me you called Richards Relics. Those prices sound right for him. There are several threads that discuss band relining. I believe it costs about $35/band to do. FYI Richard Clark just wants your money. He is in the hobby purely for profit and should only be used as a last resort if ever. AATVs do not cost as much as an exotic sports car to maintain or repair, unless you buy your parts from him.l like to buy stuff and no I don't do payments!
I couldn't have said it better myself. You must have called Route6x6/Richard Clark. Avoid him at all costs or you'll go broke trying to maintain or build your AATV. Transmission Crafters is the way to go. They're great to deal with and charge half of what Clark does.Originally posted by amphibious drew View PostMy psychic powers tell me you called Richards Relics. Those prices sound right for him. There are several threads that discuss band relining. I believe it costs about $35/band to do. FYI Richard Clark just wants your money. He is in the hobby purely for profit and should only be used as a last resort if ever. AATVs do not cost as much as an exotic sports car to maintain or repair, unless you buy your parts from him."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Yep, have them relined by Transmission Crafters and avoid Richard Clark and you'll be good. And make sure you clean the cases out well, you don't want any gear oil in there at all. 1 quart of ATF is what it calls for in the T-20. Good luck with it and let us know if there's anything else we can help you along with."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I have been reading everything I can on the t-20. I wish I had done this before I took it apart the first time. Something is bugging me about the left side both top and bottom being so loose?? I can't see both bands becoming worn out? It was that loose before I took it apart. And the right side both the top and bottom plungers barely come out of the case before becoming tight? Is it possible that the kid who took it apart before me, somehow managed to get it together wrong? also the right side will only engage if i lightly hit the lever but not at full stroke? right side plungers only come out a 1/4 to 1/2 inch from flush where left side plungers come out almost a full inch but seem to have no restriction ?
I can not imagine any scenario where the plungers would come out a full inch.....worn out band material/ put together wrong etc.
The only thing I can think of is the drum being under sized. When you get it apart, check the drums for smoothness (no gouges or pitting) and for the proper diameter. The last guy may have turned the drums down on a lathe, and got them too far under sized. Here is an old thread on the drums http://www.6x6world.com/forums/trans...html#post46427
i went through and read for almost 3 hours the other night everything i could about the t-20 issues. I found 2 threads describing very similar issues that i seem to be having. so i made a video showing first hand. now another possibility is I also had a drunk truck driving girl standing next to me being loud and obnoxious to the point i finally had to send her down the road. only thing is the levers acted the same before and after I took it apart????http://youtu.be/axj2_2USU4c
