So, I've tried to remove the primary clutch on an old engine and pretty much had everything off except for the pully side closest to the engine, of which I then tried a pully puller to remove this and eventually ended up bending the pully. So... no luck with the puller... and I've now warped that part of the clutch.
I've got another old engine kicking with a clutch on it and want to get it off the right way... so, I guess a couple questions:
How does the clutch lock onto the crankshaft so it doesn't spin? Key? Pressure fit?
The shaft that the moving pully half slides on - is this a solid part along with the other half of the pully? (the one thats fixed to the engine)
And most importantly.. does anyone have a break down of how to remove or install a clutch (the full assembly)?.. I think pictures would help me out the most.
Cheers,
Beeman
Cheers,
Beeman
