Im thinking its going to be diamond shifter pin help please
t 20 doesn't go foward or reverse on left side
Hi Chris....
Is this on your Max II? If you want to pull the shifter out to inspect it, disconnect the shift linkage, and remove the stamped steel hold-down that's held on by the two 3/8" bolts. You'll be able to pull the shifter straight up and out of the shift bore. It might be a bit tight on the O-ring, but there's nothing else there to hold it in there. I don't know how old your Max is, but I'm hoping that it's not old enough that it uses the C-clips to hold the shifter down (instead of the stamped steel hold-down that's bolted on the transmission). If you DO have the C-clips, get them out of there by any means possible, bend them in half and melt them down into molten goo so nobody else has to deal with them.
I don't know if anybody else has sourced the shifter pins from anybody else than Recreatives. If it's broken, sometimes they'll come right out, and other times they'll be a real pain. They're hardened, so don't bother trying to drill them out. Let's see where you're at after you complete the above steps...
Good luck...sigpic
