My latest aquisition may not be the jewel I thought it was. Drove it less than 20 minutes and left side of T20 is now stuck in forward gear. Right side shifts as it should. Diamond is flopping freely not engaging anything in the tranny. Anyone have any idea what came loose or or broke?
T20 stuck in forward
Either a c-clip holds it down, or there is a hold down bracket over the diamond shifter. Then just wiggle it and pull up while doing so. If you have neither, it's most likely just moved up and needs pushed back into its slot. It only takes a minute to figure out. If it is a broken pin, try to remove the broken piece and just get another one. If you can't get the pin out, someone may have a used diamond shifter laying around, or you can just get it from RI.l like to buy stuff and no I don't do payments!
