1994 Max IV Not turning right
  • 1994 Max IV Not turning right
    I need help, My Max IV will not turning right going forward or left going backwards.
    The sticks should move about 7 inches full forward to full turn. Make sure the linkage is still hooked up to steering lever at the transmission. If the right stick moves a lot more you probably have a broken band or the lining came off. Did it happen all at once? Does it drive forward ok and just not turn?
      Yes it will go Forward and back. Whats the best way to towe it? But will look when I get out there. Thank you.
        If it has its own power I just steer it with the tow vehicle and drive it. Tie to the dead side to turn it. Good luck.
