I'm trying to get my '70 Argo set up right. I'm having a hard time figuring out exactly how the clutches should be set up. I have a new 14hp Vanguard in it and a new clutch that came with it from route 6x6. I've read bits and pieces about people changing weights in the drive clutch and springs in the driven clutch to affect performance. It sure would be great if someone could explain how to set these up. How do you set them up for good low end torque and still maintain your high end speed?
Please explain how the clutches work.
engagement rpms
ALthough I am new to the 6X6 world I been an avid snowmobiler for along time and the main reasons for chaging the weights and springs was to change the rpm that the clutch engaged at. For example making the clutch engage at a higher rpm which should make your machine more peppy on the low end. Hope this helps.
