Hi All, I recently picked up a 99 Conquest. I've replaced all the chains and upon firing up i noticed that the right side doesnt want to roll/spin. With a lot of gas it work run foward about 10 inches but after that its just the left side that rolls freely. I checked the brake- its clearing the drum.
I believe the issue is with the idler chain. It took me close to 5 hours to get the idler chain on with modified needle nose. i couldnt seem to get the transmission to drop all the way. It looks like it could go an 1/8 inch down. The idler chain on the right side is tight but has about the 1/8 inch of slack like the service manual recommended. The other idler chain on the left side has close to 1/2 inch of slack and it rolls without problem. My question is do you think that my idler chain can be too tight? I dont remember there being a problem with the wheels spinning until the idler chain was installed. I dont want to remove the chain unless i narrow it down to the chain.
In regards to dropping the trans i could loosen the front bolt no problem, the back bolt i was able to get the nut off but wasnt able to get the bolt head loosend. i tried for over an hour but part of the frame is bent right at the bolt and it interferes with the ratchet. I tried banging it through from the other side with no luck. I screwed down the other bolts as recommended by the service manual to lower the trans.
If its not the idler chain do you have any other ideas? i'm able to roll both sets of tires with my hands but the right side does has slightly more resistance than the left side. If it is the idler chain whats the solution? My first thought was add another link and raise it up until i have even tightness?
