Trying to get secondary clutch of to get belt Gard off hit it with rubber hammer. spray p.b blaster its stuck on shaft i don't wont to brake clutch its on 1999 Argo Bigfoot. And yes i removed bolt and washer enemy thing to suggest. thanks Lloyd p.s bad righting.
Help removing secondary clutch
Try screwing bolt back in leaving about 1/8 to 1/4 from all the way in and pry againt hub while tapping on bolt head, be sure your bolt is in several threads or it will bugger the threads up. you can also use an air hammer on the bolt head if you have enough room to get it in there. Keep spraying with PB it'll come off
