Which belt U using and WHY?
  • Which belt U using and WHY?
    First what belt do you use, and why? Is it stock or aftermarket?
    I'm just curious....
    Now for me, my Muscateer has a Dayco GTS 705 belt and it's worth TF Out! I called Dayco Canada, they could not give me a part # of a replacement belt as the GTS 705 is some antiquated version of an ancient relic no longer available, maybe was new when Moses floated down the Nile I gather!
    Dayco Canada gave me some engineers Tele # in Texas IIRC to contact and find out what I should use.
    He crossed it to an HPX 2237 or XTX 2248, now the HPX is for 500-600CC engines, hmm...450 cc 12 Hp Techumseh...good enough!
    I bought a new belt today, sanded my primary clutch faces and wiped with Zylene to clean off the dirt and debris.
    After installing the new belt, I did a quick test drive down the same back orchard drive and on the same paved back road and got 15 and 17 MPH compared to 12 and 13 MPH previously.
    Now I also may have gotten rid of my engine today and that means the diesel goes in so this new belt may not be long for this machine
    Regardless, I thought I'd throw some images of my belts up for you to see. OMG does that old POS look like a POS next to the new one. Now to go and test the rig on the hills to see if it can climb any better...but without a torque clutch and only that speed secondary clutch that won't down shift I'm not thinking it will be a big improvement.
    Anyway have a look, was it time to change
    This old belt..ya supposed to be same width as new belt LOL
    Can you say WORN TF out?
    Suffice it to say it is a big improvement overall in response and now to see if it can climb.
    Hoping it makes a difference, I'll be testing and reporting back soon enough
    Thanks for looking
    Al
    MUSCATEER 6x6
    MUSCA TUR BOTA then eh?
    94 F350 4x4 7.3 IDI ZF 5sp
    Al "Camo pants"
    I use a GATES G-FORCE BELT 28G4573 because of the torque and power of the diesel. pus it was the closest to the size i needed
    1996 MAX IV ,KUBOTA DIESEL
    MAX II 30HP Bandolero
      I always use Gates belts. Always had good luck with them and they are sold everywhere.
        Well this belt is a very significant improvement over the ratty old one for certain. I was able to get down to and up out of the river with nary an issue at all.
        A change to a different secondary would be helpful too one that shifts instead of not shifting like the SPPED clutch I have.
        All in all I'm pleased with the change, and I'm considering the gates when I get the diesel installed!
        MUSCATEER 6x6
        Al "Camo pants"
