So correct me if i'm wrong.... I have a late '97- early '98 Max II...(serial number 13403) I believe my machine would have a comet 780 clutch correct? and After '98 didnt they come out with a new primary clutch spring kit to help the primary backshift better and achieve a better top speed at the same time? does anyone have any information on this? Color of springs etc. The reason I am asking is my machine has a 18HP vanguard motor and the machine will barely climb hills. As if the clutch never backshifts, by the time I get to the top of the hill the machine is just creeping like it's stuck in high gear. I know what you all are thinking. condition of belt, tension, holding sticks forward blah blah blah. Well the tension is good, the belt is a brand new factory belt, and even though i don't have springs on the sticks I am definetely putting enough pressure on sticks. No doubt in my mind. Also the top speed of my machine is a mere 22 MPH on paved road on a good day which I would think is slow. So I would like to install this so called "high speed clutch kit" and a red driven spring to aid me in climbing steep hills I know these machines should have no trouble with. Only thing I havent done is watch the clutches when i'm going up these hills..... But to be honest I wouldn't 100% know what I was looking for anyways. So if anyone could help i'd highly appreciate it. One day i'll return the favor.... One day.... with cold beer possibly
After it's open, you can pull each arm back a little further off the spider with a screwdriver and roll the bushings by hand to see if they have much slop. The Comets/Salsburys seem to run for decades with a ton of slop, but that doesn't mean it's good for them, and they will eventually throw a roller.
I am going to try and find the thread where someone states about an "update" so to speak on the clutch. I don't think I was dreaming it
I found it. In this message HEY_DAN mentions in the bottom of the post about this update kit because from the factory the clutches did not utilize the entire clutch. So that coupled with old worn out springs could be all my problem. It did cure the guys problem in that post originally. Same thing like you said hydromike. Probably all worn out springs and rollers which seem to come in this "kit" anyways.
