I recently had to remove both clutches from my Argo response 99, with 18hp briggs vanguard.
It seemed that they have never been removed before. I've tried what has been recommended by Rock Doctor and others on this great site - didn't work for me.
I've ended up spending half an hour making custom pullers.
Primary:
Weld straight or U - shaped piece of metal (depends on the depth needed to start the nut) across the nut, and then use the tread on the clutch end to pull it off the shaft by slightly undo holding bolt (or few inserts into the bolt hole if bolt is absent, as it was in my case).
After you're done, simply grind off welds to reuse the nut.
Secondary:
I've drilled and tapped 3 holes (5/32" coarse) in the aluminum base. Drill deep holes, at least 3/4", and tap all the way. Then I have used regular balancer puller to take it off the shaft. Better use Stainless Steel hardware as they are stronger than regular hardware of mild steel.
Both worked great. Given how hard it was to pull them off the shaft, I would not be able to take them off without damaging clutches, engine or transmission.
Hope this will help someone to save some time
Primary:
Secondary:
