Well I'm changing over to a red spring because I read so many good things about it. Now that I got the green one out and next to the red there's not a whole lot of difference. I see the wire diameter on the red is.005 thicker. This hardly seems like enough to matter. Any advise on this would be greatly appreciated. Thanks.
Green and red spring difference
Could it be a different material?
Tempered differently?
Does it have same amount of coils?
Same inner and outter diam?
Try it, if it makes a difference that you can tell, report back!MUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
The t20 is a CVT Transmission, the red spring keeps the machine in the lower gears longer than the green spring, the red spring is more for mudding and power control and may limit the top speed a bit. I do think the red spring is one of the best mods out there and all my T20 equipped machines have it.
Well it's going in and if I like it I'll put one in my max with tracks that one could for sure use a little more low end. Especially with two people in it. Thanks for all the information. This site has been a wealth of information.What it lacks in ground clearance it makes up for with traction.
HI
The red spring compared to green holds u in a lower gear longer and yes it accelerates a little slower than the green. Due to the down shift characteristics of the red spring full speed will not be achieved until on hard pack sand or similar . Always make sure u have the correct colour of spring for the generation of clutch . In the 700 series of driven clutch besides having different sizes eg the 770 780 790 there are also different generations [or series ] 3 types very early 1962 till early seventies.
seventies till mid nineties ,,
nineties till current
As u can see there are also other red springs [and other colours ] for the different generations THEY MUST BE MATCHED
tomo
