I am rebuilding a t-20 transmision and having trouble getting the shaft retainer c-clip off! It is a c- clip w/o holes for snap ring pliers. It wraps around about 7/8ths of the shaft! Looking for any tricks to get it off! It is the clip inside by the bearing!
T-20 transmision shaft retainer
There's a set of pliers with a knurled flat surface on the end that work really well for those. Check out the third page of the T20 rebuild article: Rebuild your T20 - Page 3 and you can see a picture. There are other pictures further in the how-to that may give you a better view of the pliers.
I've had a pair of the ring pliers with the flat external knurled surface in my toolbox for 20+ years and I still had trouble with that clip. My pliers were just too big to get a good grip on the clip with the teeth of the shaft in the way. I wound up getting a lock ring plier made by Channelock from Home Depot yesterday that did the job in only about 3 tries. They switch from internal to external lockrings with a lever and come with a few different tips for different lock ring types. Cost about $22.
