780 Series Clutch Offset
  • 780 Series Clutch Offset
    So, I've searched around and read some of the clutch offset/alignment threads. And the only thing I've found is the picture that says 3/16 to 5/16 offset. Does anyone know what the offset should be for the 780 series clutches. I'm thinking about going 1/4" right in the middle.
    Courage Invites Critics
    Here's the photo I was talking about.
      I found this while searching around online it has alot of good info on the 780 series.
      It looks like the offset is .24".
        Thanks for the follow-up. It will help someone else down the road.
          hi
          Clutch Alignment is a very ""loaded question ""
          1st ask The 700 hundred series of clutches comprises ...drive 780 ... 770/780/790 driven
          Due to the different different driven /secondary sizes
          The clutch total diameter is biggest on the 770 and smallest on the 790
          The cvt belt operates in different diameters for each clutch diameter
          The different diameter causes different offset/sideways travel of the belt
          Therefore the offset should be different for drivens to drives
          2nd
          Offset is dependant on wear u want the belt to be the straightest at whatever rpm
          A straight belt is the most efficient power transmission
          Typically also varies 2 or 4 stroke [2 stroke almost double the rpm of a 4 stroke ]
          Gearing selection can influence this
          A belt that is not in some form of alignment at the most commonly used rpm for your machine will wear faster
          780 drive 770 driven I setup to the same as a max 780drive 780 driven which is using the inside edge[side closest to engine ] of the engine clutch inline with the corresponding driven with a piece of string .. Works far better than having a larger offset
          tomo
            Thanks Tomo, I'm glad I didn't bolt down my engine yet. So just line them straight up and I should be good to go.
