What you know about clutches?
  • What you know about clutches?
    Tearing into the magnum over the last few weeks has led me to taking apart the clutch. I've had my fair share of clutches apart, and the powerbloc seems to be pretty simple and effective. But, the stationary sheave does not want to come off the engine, and the secondary doesn't want to come off the transmission input shaft. So, I know the primary is going to need a bit of work even if I can get it off the engine.
    Since I will need to get a PTO shaft and plate made for the yanmar, I was thinking if I use a snowmobile clutch, I can get the PTO made as a tapered shaft.
    Any thoughts on this? Anyone?
    I don't think you could ever get a 2 or 4 cycle snowmobile drive clutch tuned down to engage and pull properly @ low RPMS, We have made and used many tapered PTO's shafts over the yrs.
    Kawasaki mules and John Deere gators ran a nice tapered drive clutch. If you don't mind spending a little more money than this is a bullet proof and fully tunable unit.
    1" Straight Shaft Roller Clutch
      That clutch is probably threaded on the crank.
        The Kohler clutch, that is.
          how much? how tunable, can it be made to work for a diesel? engage 900 rpm full shift by 3400 and top rpm of 4K
          MUSCATEER 6x6
          MUSCA TUR BOTA then eh?
          94 F350 4x4 7.3 IDI ZF 5sp
          Al "Camo pants"
            I never tried to get down to the 900 rpm range but that one listed shifts out @ 3,600 with a matched driven. there 400 bucks but are the best out there, give em' a call
            Aftermarket & Motorsports Products & Sales
            If you are a retail customer interested in TEAM Aftermarket performance products, retail orders, technical assistance, tuning recommendations, and other "shop talk," please contactTEAM Aftermarket at:
            Email: TEAMMotorsports@TEAM-IND.com
            Phone: 218-844-3283 Tech Line Direct: 218-846-6305
            Website:TEAMaftermarket.com
              It interests me. $400 + ship & customs might be a little more than SWMBO will allow right now, since we might get stuck owning two houses for a while. We shall see.
              Riotwarrior, if you find out how tunable it is, pass on the info. I don't know how low my idle is going to be yet, but I'd like it to engage a little lower than just mid range. I'll be able to go to 3650rpm with the yanmar.
                Ill check with them next week, it is quite a bit more $$$ than I'd like to spend and I think I would work on replacing my secondary first for now but I will investigate it thoroughly.
                I just for chitz n gigglz ahem...turned up the throttle stop on my IP and now have gone from about 3600..+- to an indicated 4015 +- RPM and my primary 780 clutch with new weights springs is at full shift, I can't wait to try it with the new full **** and 4K rpm and running down the road, I'm guessing near 20 mph or more, last test was with gas and I got a total of 17 mph downhill.
                Rudy I assure you, you will not be disappointed with going the diesel route what so ever, not ever remotely as it just chugs n tugs along.
                MUSCATEER 6x6
                Al "Camo pants"
                  Have a tapered one off Gator for 150. plus shipping, has tapered shaft unless you want to turn it or the pto shaft.
                    Primary or Secondary? LOL
                    MUSCATEER 6x6
                    Al "Camo pants"
                      Primary, just like the one pictured.
                        How much use has it seen?
                          So, the CPP clutch is essentially just a TEAM clutch. They sell them for the same price as well from their website. 1" & 1 1/8" straight shafts, and one for taper shaft. All same price. The thing with a taper shaft is, I will have to get everything exact for measurements when I get the machine shop to do my PTO plate & shaft for the Yanmar. With straight shaft I can just put some spacers in to adjust. I'm trying to find a Canadian distributor that's not far. If I can save on shipping and import fees, that helps a bit.
                          Doing some research on TEAM clutches, you can get weights that are adjustable. They have three different weight locations, and I guess that's how you can adjust for engagement rpm and shift point. They do offer one on their site that comes with adjustable weights. Might be worth a look. I'd probably rather get one from TEAM than CPP.
                          On another note, Jim, can we get a picture of that Gator clutch? What machine is it off of?
                            Team just started a retail website and that's where to buy them now for sure. the weights and spring combos lets you control engagement and bite/torque needs. they have great tech support and will match a kit for Your application.
                              Figured I should post this here to get more exposure:
                              Thought I'd give the primary clutch another try after the penetrating oil worked its magic for a few weeks. Put an electrical cord down the cylinder (couldn't find any rope in the shop) and gave the clutch a good twist and it screwed right off! Now, the question is, should I use it again? It is worn a bit down where the belt engages. What do you guys think? Is it too worn?*
                              Also, the bushing is gonna need some love. It is just flopping loose on the shaft, and you can tell it has been for a while. If I can run this for a bit, then upgrade to a TEAM roller clutch later, I think that might get the green light from the wifey. *
