during this rebuild on my 83 max2 the driven pully stayed open after reven up the motor it is stuck open is this a bad spring? just have to fix one part at a time thanks ART
driven pully problems
Yes but be careful. Once the pulley is off there is a snap ring on the end. Remove the snap ring and it should come apart. If it doesn't try some lube just make sure when you put it back together that you clean all the lube off. I made a jig to take them apart but I've used a large vise in the past, a second set of hands, long bolt with washers and nut. Just remember that it is loaded with a lot of spring pressure unless your spring is busted.sigpic
