Who wants to do a rebuild on the sight I don't have time to do it lol
t20
Ok, case half gaskets and bearings must be purchased through MuddOx. Bands can be relined, and you can search the forum for places to get them done. Many members have had some redone. The other option on them is new from MuddOx. They have made improvements, so new May not be a bad route, but relined is a fraction of the price. O-rings you can get anywhere for the plungers. Sprockets you really shouldn't need, but there are a few options. Obviously MuddOx carries them. Heck you can get any new t-20 part from there, but Whipper can also make you a set of sprockets. He can change the size even if you desire. He does great work and is a very valuable member of our community. You will need to helicoil those messed up holes in the t-20, and probably want to do the 2008 frame upgrade while your at it. I believe the specs on the kit are listed somewhere from the homepage or you may be able to get it from MuddOx if you don't have a local fab shop that will make you up one.l like to buy stuff and no I don't do payments!
Here are your bearing #'s
input shaft brg: BH1612
planetary brg: BH168
input shaft inner brg (only on old style trans): B910
output brg (must be machined, 17mm thick stock needs to be 15mm thick): peer N6207
And the seal #'s
output shaft seals #17184
input shaft seal # 9878
plunger o-rings #018
shifter o-rings #117
Drew is correct on the case half seals, buy them through Mudd-ox, Or the whole rebuild seal kit as it is only a little $ more and you get new clips and fiber washers too.
I'd also suggest buying the output bearings from Mudd-ox too as surface grinding them is a real P.I.T.A.
Thank you the trans seems to work fine it is just leaking out of the plungers there is a lot of sand built up around the sprocket drives like it's seeping from there it just needs a good cleaning for sure man I just don't have the Patience for this thing anymore I love spending a ton of money on it and didn't even get to drive it yet what a damn joke it just makes me sick
Originally posted by freestyle7783 View PostThank you the trans seems to work fine it is just leaking out of the plungers there is a lot of sand built up around the sprocket drives like it's seeping from there it just needs a good cleaning for sure man I just don't have the Patience for this thing anymore I love spending a ton of money on it and didn't even get to drive it yet what a damn joke it just makes me sickl like to buy stuff and no I don't do payments!
Well everyone has helped me out and you too has made me realize how much you can learn on your own by reading tons of posts so I did take another step tonight and removed the clutch off the Trans with the techniques that buggyman said to try so it's done next tomorrow are the band bars one step at a time
