Is there any way to tighten the drive belt on a 02 Conquest? As soon as i go WOT the belt flips over. I thought it might be a bad belt so I got a new one but still have the same issue.
tighten Drive belt on Conquest
It sounds like alignment problem to me. Try to check all the engine mount bolts and transmission mounts. Also if you can fit a thin ruler behind the engine clutch on the flat back side. With this see if clutches are aligned with each other. With belt off check both clutches for any play in and out if retaining bolts are gone or loose. My thoughts I'm sure there some more.
