baker hill tranny question
  • baker hill tranny question
    I bought a used rebuilt 7000 tranny for my 208. The guy i bought it from said he rebuilt it, I'm not sure if he knew what he was doing. The problem is that both outer bearings are a quarter inch out of center to the right of the bearing caps after the main center bolt downs are installed. The sprokets also are out of line to the right. Does anyone know of anything he could have done wrong in assembly that would cause this?
    sounds to me like the outer snap ring groves are broken/worn off the main shaft
    and the next grove in was used. the first grove is maybe an 1/8 inch in from the end of the shaft. (on both ends)
      Thanks, both outer groves are there. It all seems like there is a 1/4" shim inside the box that is on the wrong side moving both shafts to the right. The calipers are off a 1/4" inch also. I'm going to go back out and study it a little more. Does anyone have an exploded view of the 7000? The one i found at the manuel page here i cannot see all of the tranny.
        The better view is of the 5000 tranny, same parts just different sizes.
          Where do i find that pic? I'm making progress, he had some snap ring on and others not on. I now have it centered but now it is hard to shift. Going to move it back a little and see if that helps. I think its still missing some snap rings somewhere because when i try to shift everythig is moving. I got this tranny for 20 bucks and don't mind working on it, I learn that way.
            Sounds like you figuring it out you will be a pro at it in no time.
            I rebuilt my first one not long ago. It shifted a little hard before and after rebuild but works great.
            Did you see this page it helped me out http://www.6x6world.com/forums/conte...r-manuals.html
            ST400R ATTEX(Smiley)
            500 Super Chief
