t 20 adjustment
  • t 20 adjustment
    hey guy's , don kenyon and i installed new bands saturday in the tranny. just took a test spin. i have always had the springs on and like them. don adjusted the tranny before i installed it. now going forward i have to push the sticks to get up a hill. also in a turn, before i just pulled the corresponding lever to turn. now i have to pull the stick back and push the opposite one forward. wondering if both band bolts need tightening on each side, top and bottom or just top or bottom , etc. reverse works fine. thanks for info. johnboy va.
    by the way, when pulling back steer levers, distance top moves back is 4''. johnboy
        no, the springs are on, but still if i pull back right lateral to make a right turn, i also have to put forward pressure on the left one and vice versa. before i just pulled back allittle and it turned fine. no need to put pressure on opposite stick. thanks again. johnboy
          Tighten the springs first and see what happens, however, tracks need more force. Things may need to wear in a little, if still acting up after an hour or so adjust bands a tad.
            thanks jim, i read the t 20 adjustment procedure last night in the forum .. how to adjust without the spacer tool. i had a set , but never had any luck with them. the main info i got was that when channel is pulling plunger out, the re should be about a 5/16 '' distance between channel and trans body. also if the band were adjusted too tight, what would that feel like and operate like ? thanks again johnboy va.
              Can you turn the t-20 output sprocket by hand with transmission engaged in forward with stick in a neutral position meaning not braking or pushing sticks forward. Is it dragging if not run it a few hours. I put mine back together and had a little neutral spot with transmission engaged in drive compared before putting new bands on. Plus if don helped you I think it would be perfect for running.
                I adjusted the bands in our Max IV using the spacer tools and a inch-pound wrench. It worked very well. Maybe give it a try?
                  thanks for the replies friends !! don's adjustments were close. just had to tighten the bands a hair and tighten the springs allittle. works really well now, slight pull back and i get a good turn. ready for busco. johnboy va.
