Was just wondering if there are different sources for t-20 bearings. I believe that I have a bad bearing on the drive side of my popcycle t-20. When in neutral, the right side is very smooth. The driven side seems a little rough. I was hoping not to have to get into this t-20, however, i'm not going to reassemble this machine if there is any doubt in my mind that there is going to be trouble! Any response will be helpful. Thanks. Bryan
T-20 bearing
Referring to the output shaft bearings unfortunately your answer is no. You have to go through the manufacturer or buy on Max6x6.com. Reason being is that the bearing is a special bought bearing that the factory has turned down to size to fit in the case. Meaning you and I cannot physcially go to any bearing house and get a bearing that is going to fit. Sorry for the bad news. Especially seeing as that is the last thing to come out of the T-20 when dissasembling. But if the transmission is out of the machine I would say now is the time to take care of the issue
Hay man, just got a P.M. And was told that another site member is making these bearings currently! I will be sending a P.M. To his better half! When I P.M. Him, I get an error message! If the price is what I am told, I will be buying enough to do both of my T-20s!
