T20 Mod Help
  • T20 Mod Help
    Hi Guys
    I recently overhauled my Max and did a mod on the T20. and after 3 hrs I have found an issue. I am using 4 bearing rod ends and 1/4 inch flat bar to replace the U channel and bolts. When I drilled the flat bar for a pivot point I get a lot of binding between the travel. In center position all is good.
    I see that the original U channel bolt holes are elongated to allow some play but using bearing rod ends there is no play.
    it would appear that using bearing rod ends and a pivot point would be simple. not sure what I did wrong.
    I had the pivot point on the T20 area machined to 4 1/2 degrees.
    can someone help me with some specific explanation and maybe pics on how they did there's and then I will be able to figure out what is up with mine.
    Hopefully I explained myself.
    Thanks for any help
    Looks like there is a ton of movement there in the hiems.
        Eyebolts were my thoughts, had also thought shoulder bolt but lock nut will let it float.
          Awesome.
          Now I get where I went wrong. thank you all for the responses.
          Larry
            Things I did wrong on my Mod. hopefully someone will learn by my mistake
            1. I drilled the T20 case first and then tried to drill my 1/4 stock to match. Drill 1/4 stock or channel and case at same time to insure all is in line.
            2. elongate the plunger attach hole to aprox .625 inch. I did not elongate my holes and binding happened from neutral forward and neutral rearward.
            Follow the simple instruction that other people have done, which I didn't and you wont have the issue I had.
            Larry
