I would like to know if anybody has any idea what alloy T20 drums are made of. I know there made of cast steel that is heat hardening. I have installed sleeves on a pair with parts of a old drum. Both had one edge worn off about 1/4"+. Sleeve are pressed on but I want to tack weld at outer edge to secure them. Undecided as to TIG or MIG them. Will probably do 6 short welds as to not create a lot of heat. Input greatly appreciated.
Welding T20 drums?
Keep us updated on this. If you contact Buffalo Gear they may be able to tell you since they've made the T-20 components for a while.
Buffalo Gear, Inc. > 50+ Years of Precision Gear Manufacturing"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I pressed them on but haven't welded yet. I thought they were cast steel which welds well. Iv had a bunch that other people welded and were not turnable in a lathe. When I install the reverse gear inserts I pin them into place. Thanks for the info. Will have to do this one in the next couple weeks.
Had time to spark test yesterday. It's ductil cast iron. Comparing sparks to ductil iron pipe sample very close to the same. Only hi nickel wire in town is a 42 pound roll. I have a lot of nickel rod and all I want is about 6 dots on the edge. I'll get back to it next week.
