help changing rollers/springs in a 780 comet clutch
  • help changing rollers/springs in a 780 comet clutch
    want to change rollers without puttn an eye out...any help would be appreciated
    Salisbury clutch manual is on this site. I don't remember the driven as being to bad to repair. If you pull the one pressed on part off to change the bushing they reccomended replacing it. If you don't replace or drill and pin together it eventually spins out. If you are just changing springs and rollers your good to go.
      Thank you I'm putting the machine together now hopefully this will work out it was a little tricky getting the springs back into place on each side of the roller but after 20 tries on the last spring I finally got it and considering I have the body of a better go over everything and check make sure everything's okay it's really a pain to lift the body off of there unbolting at removing the floorboard even though I split my floorboard into pieces
        Where does a guy find a rebuilt kit for the driven? Or do you have to replace the whole thing?
        Mine has a bit of wobble to it.
