So, I have one diamond with a broken pin. The pin has snapped off below the surface of the diamond shifter body. It is undrillable (but I guess you all already knew that. I had to try right?) Has anyone successfully removed a pin that has has snapped off below the surface? And how? Local heat to ruin the temper of the pin? Attacking the pin with a tc drill or diamond tipped dremel tool? I am a bit shy of damaging the body of the shifter as replacements are close to 100$ plus shipping to Europe.... If I can get the pin half out I can find a replacement pin. Dimensions I already have (courtesy of searching this site
) But how to get it out.... any hints appreciated.
Also, what about the broken end? Can I just leave it floating around inside the T20? I watched a youtube video that suggested that would be fine but really? Is that ok? What are the chances of that small bit of very hard steel getting wedged up and causing BIG damage?
