Hi. After a test ride of our Max IV the machine wouldn't turn left in reverse.
Then it wouldn't turn going forward. Then it wouldn't go at all. Then it ran fine.
I adjusted the bottom plunger bolts inward about one to two turns.
At first it seemed to run fine forward, but wouldn't turn rear left, then it wouldn't do anything.
What I suspect is the bands need replacing. Could this be the case?
I also considered that the woodruff key on the secondary is broken. I lost the original on the ground but could not find it, so I installed a new one thst is a tiny bit thinner. Could this be causing the issue?
In either case the engine and trans will need to be pulled out.
Also, how does the T20 actually work? I pull the right lateral, what goes on inside it? Pull both laterals, what goes on in there? How does it work?
Thank you for the help.
