1190 clutch disassembly steps needed
  • 1190 clutch disassembly steps needed
    Can some one assist me with how to disassemble the drive clutch/pulley from my Max IV 900T. The clutch is removed from the engine. I appears to be a model 1190. I want to dissemble, inspect, clean, and lube it.
    Thanks
    I may look slow but....
    Thanks
    is that the motor clutch or the tranny . i have dis the motor but not the tranny . robbie
      It's the engine clutch pully. It appears to be a model 1190 it has three nuts on bolts, that lock in place with either cotterpins or lockwirer, around the bolt the holdes the clutch to the engin shaft.
      Any help is appreciated.
        I believe you have to leave the three nuts and cotter pins on the studs and press the whole dome piece off the splined shaft. A buddy of mine went through his. It was much different than my 780 in my Max II. I would call RI and see if they have instructions.
          Dome cover or side of pully & dome cover
          Thanks for the info thus far.
          Does anyone know if I press off only the dome cover or that side of the pulley and the cover?
          Thank You
            It's a little late but for future reference here's a copy of the service manual for your drive pulley. go to page 15. http://www.vintagesnow.com/Clutch_fi...ShopManual.pdf
