Hi all,
While pulling my transmission apart, I found someone had siliconed the center plate into position to prevent leaks... Didn't matter than the oil seals on the bearings were leaking like sieves, but hey, they did and so I couldn't remove the divider.
I'm not sure what others have done in this situation, so I made up a small piece of 3D printed plastic so I could use a case bolt to lock into the plate and then attach it to a panel pulling hammer and gently tap the center out.
IMG_20191214_180423_1 (Small).jpgIMG_20191214_180440_7 (Small).jpgCapture.jpg
There's a STL file I'd like to upload as well in case anyone wants to print themselves up one? Does anyone know how I can upload a STL file? Thanks.
David.
David.
