What size are the case bolts, mine are MIA, but as soon as u get off work I'm going to grab some but I'm stuck at the parts palace til 830.
T20 case bolts
if you mean the bolts holding the 2 case halves together, 5/16-18x 1 3/4 will get you where you need to be.
you will need 9 of themA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Dan,
I use 5/16-24 socket head cap screws with a split lock washer under both side just to keep the aluminum from distorting, and nylock nuts. you will need a 2" bolt to make up for the extra washers and nylocks.
No more loose bolts and loss of trans fluid.
It's a small price to pay for a much larger repair bill.
I did end up using 2" x5/16 bolts but used flat washers, no leaks yet, but I may switch for lock washers since the machine isn't totally assembled yet. I've been slacking on my rear chain tensioners and getting it in the tub.Originally posted by mfenmor View PostDan,
It's a small price to pay for a much larger repair bill.DanW
