hey. I ran my max for about a hour. and when I got done I noticed the top plug on the trans was leaking some out the vent in the plug. the level was correct before the run, just wonderingif this is normal or If I have a problem that needs to be fixed... thanks again Jeff
t- 20 top plug leaking
Hi:
Level was correct, as in filled to the BOTTOM plug? (drain plug, 1 qt of fluid) and how much leaked out? was it "wet" around the vent in the plug or was there a good amount of fluid that leaked out? I've seen that the area around the vent gets "wet" but since fluid is spashed around, and the temp increases and air comes out of the vent, a few drops will also get pushed out, but if your leaking a lot of fluid then I would think either A: your overfilled, or B: you're getting a little wet from the vent but also leaking from somewhere else.
Attex Super Chief - Sold.
the level was correct, and it was't a whole lot that was there, just wet around the plug with maybe a couple of drops running down below the plug. I did a lot of donuts in it that day going back and forth down a driveway, so maybe that caused it. I will check the level again and see if it need some added to it. thanks
