Help
I am trying to remove the driven clutch on my scrambler how does it come off the shaft?
is it a shiv type press fitting or is there some special tool I need to get it to move? I have removed the slip fittings from both sides which were held in place by set screws now I need to move the clutch
There are 3 bolts equally spaced around the clutch on each side that look like they line up but Im not sure if removing them is the thing to do, I dont want to screw up and have a mess trying to put it back togather
Thankyou for any info
tlp
is it a shiv type press fitting or is there some special tool I need to get it to move? I have removed the slip fittings from both sides which were held in place by set screws now I need to move the clutch There are 3 bolts equally spaced around the clutch on each side that look like they line up but Im not sure if removing them is the thing to do, I dont want to screw up and have a mess trying to put it back togather
tlp
