T-20 transmission belt tightning for diffrent engine
how tight should I have the belt on the clutch on the motor should I have a little play in the belt or should it be kind of tight on the shaft it is in a max 2 I dont know what the tension should be any ideas
If you will use the search here on the site there are several threads that go into detail on this topic that will probably help you out. Here's one I got from the search: http://www.6x6world.com/forums/trans...-question.html
