Aligning the clutches
Hey Mike,
You may want to use angle iron to align the clutches rather than a flat piece of metal. The flat could be slightly bent and throw you off. I used angle iron and rested it against the right outer edge of the driven clutch (if that makes sense) then on the top of the drive clutch. Once you think you got it right, slap the belt on and do it again to see if the angle iron and belt are parallel. Just a thought..
Mike
Hey Mike,
Mike
. I'll keep 911 on speed dial...
I believe your belt is factory defect because that is strange to me for it to rip like that. I have had some pretty mismatch clutches run with out doing that. Although Im sure they wore down a lot quicker.
