I have a jackshaft torn down with almost every part removed. The holes for the shear pins are a little warbled out, so I want to have my machinst make a new shaft for me. But I have no idea how the actual torque converter comes off. All the snap rings have been removed, clutches off, etc, etc, etc. Can I just beat the shaft through since I am replacing the shaft anyway?
Removing torque converter from shaft (Terra Tiger)
Originally posted by simpleton7016 View PostI have a jackshaft torn down with almost every part removed. The holes for the shear pins are a little warbled out, so I want to have my machinst make a new shaft for me. But I have no idea how the actual torque converter comes off. All the snap rings have been removed, clutches off, etc, etc, etc. Can I just beat the shaft through since I am replacing the shaft anyway?Acta non verba
in a clutch......
soak it down good a few times for a few days in pb blaster or something..then....(they do get on there kinda tough sometimes) As jersy said sanmd down the shaft remove rust , other bad stuff....Try to carefully... using a dull metal wedge or chisles, get between the brake disk and the clutch,, tap is smoothly a few times, to see if it moves, if not heat it etc I just did one today. It came right off, no heat..
Soon See "Return of the Tiger."
torque converter
Hi
Be carefull if you apply heat when I did mine I got too much heat and the alum hub came apart and wrecked the whole thingthen I had to buy a new one at a cost of around $285 then I had to have a new shaft made which worked out better anyway
Good luck
tlp
I never was able to get the torque converter off of the shaft. Now that I have one running Terra Tiger, I want to reassemble this shaft and test it in the "runner"
QUESTION: can I sandblast the shaft, torque converter and brake disk? Or must they be filed, turned or sanded?
Thanks in advance.
Erik
You can blast the shaft, but I don't think it would be a good idea to blast the wear/friction surfaces of the torque converter and brake disk. You also want to be careful as to not get heaps of sand in the torque converter hub. I know blasting is messy and the sand gets in everything, so make sure you clean the hub real good and get all the sand out.It's all just nuts and bolts.
