red spring change out???
  • red spring change out???
    How hatrd is it can i do it in a couple hours at night is it worth it let me know asap so i can jump into it tonight if its not to hard? thanks in advance
    1996 MAX IV ,KUBOTA DIESEL
    MAX II 30HP Bandolero
    I'm going to be getting together with JerseyBigfoot this weekend to do this, among other things.
    I was planning on filming the process of switching out the red spring as well as removing the governor on a Briggs 16 hp and putting in a rev limiter kit.
    I'll post the video here in a week or two.
      the actual change of the spring shouldn't take long, but in a max 4 it may take a while to get to it. you will have to remove the driven clutch from the trans to change out the spring. i don't think you can remove the clutch with the trans in the machine?? if not you will have to remove the engine, then the trany, then the clutch. a couple hours depends how fast you are with the wrenches.
        That would be great if you could film the process of switching out clutch springs!!!!
          AGREED!!! This would definately be one for the "How To" section!!
            thanks
            thankyou for all the speedy replies im going to try and change it in the max and if i cant ill just wait till i have more help
              Changing the spring in my Max IV took about 2 weeks and a few hundred dollars.
              The rear sprockets were gone so they all needed replaced. It is a little trickey to get the preload on the spring and get everything pushed back together. I think someone showed a picture of a home made jig to ease the installation process. Make sure you mark the slots the original spring is in and add some other markings on all the movable pieces to get it back togehter the same way it comes apart.
              The pieces tend to launch themselves to the other side of the shop.
                Ill say! Lance I think I found your snap ring in my driveway.
                Acta non verba
                  NO WAY!!
                  well i decided not to screw with it i will reseal my axle flanges grease my bearings tighten my chains and call it a day
                    Maybe this will be helpful.
                      Very cool video.
                        thanks george you and marc did a fine job . that looks easy . but i would still have marc or heydan do mine . jest to make shure it's right . robbie
                          George,
                          Exellent how to video.
                            Good job guys,
                            One question, It was 92degs today why the jackets?
                            Whipper
                              Excellent Job George. I like the part were the spring flew off. lance can probably find my snap ring closer to his home.
                              Acta non verba
