t-20 Diamond Shifters
  • t-20 Diamond Shifters
    I have discovered that I have a diamond shifter with a pin that looks like a triangle and the other is perfect. First question is can the pin just be replaced or does the the whole shifter have to be? In either case where is a good place to buy the shifters?
    If you can get the pin out you can replace it but its pretty tight fit.
    Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 sells them.
      Is the pin just a plessed in? Can I just purchase replacement pins or do I have to buy the whole diamond shifter?
        The pin is just pressed in.
          I ended up ordering a new diamond shifter and an extra pin to see how much I can screw up my old one getting the new pin in. Got them from MaxATV. Thanks for the number Larry.
            Put it back together today after work and it goes forward and backwards great. Can't wait to take it and get it dirty.
              Pops out of gear
              Turns out this is what's wrong with mine too. Thanks. Thank goodness I didn't have to go into a T-20 rebuild!
                Is it common for these to wear out? I'm hopeing they are designed to wear so the trans doesn't. Is that a accurate guess?
