Took the t-20 apart, humidity got to it, has that light surface rust on the drums, should i try and rub it off with a rag, say screw it, fill it with fluid and go and just change the fluid sooner, or....
T-20 + suurface rust
Scotch Brite will work as long as the rust isn't heavy. I like fine emery paper if the rust is thicker. No matter what you use, make sure everything's cleaned up really well with solvent or brake cleaner and blown off with compressed air before it goes back together. I usually dip everything in clean ATF as it's assembled.Stuck in the seventies- not in the swamp.
